- Jul 13, 2018
- St Helens, OR
- Express 265
Your conventional wisdom comment is correct. However, in this case, I believe he's only about an inch or two from the transom which is close enough as makes no difference. The rest of what we see are trim tabs. Or at least that's how it appears, anyways. If it's trailering well at highway speeds and reacts well to an emergency lane change maneuver, including under braking - all good.I disagree, I think conventional wisdom is to support the hull all the way to the transom. It looks like about 16 inches hanging out over the rear, probably with a couple of v6's beyond that, bouncing down the road, putting a lot of stress on the transom to hull to stringers connection.
My guess is that whoever set up the trailer had avoiding the tabs as a higher priority than fully supporting the hull. If you have auto-retract to raise the tabs when the key is off, it should not be an issue.
Look closer at where the bunk is aligned - it's aligned with the pocket (which is part of the transom). There is no (purposeful) room to have the bunk extended further aft. The pocket is a very strong part of the transom.
2000 26' Grady-White 265 Express
The tab is not in a pocket, the actuator is. You can call the shallow recess where the tab sits a pocket if you want. The point is, on the OP's boat, he has 9 or 10 inches of tab, at least 3 inches of hinge, and 2 or 3 inches of glass before he gets to the end of the bunk, leaving that much of the hull unsupported.
You're overthinking that part. The rear of the boat is fully supported. That line of thinking is not what is causing what you saw - that's a relatively common thing to see. It's just the way the boat is sitting on the trailer and trailer flex. What you could do, though, is move the winch up so the line pull is more in a straight line. A little bit down is fine, though -but the bow eye SHOULD BE locked in under the bow roller.But then this last weekend, I was replacing the winch strap and when I unhooked the old one with the boat on the trailer, the front of the boat lifted up, like there wasn't enough support at the rear.
Yes, and no. If you have the correct setup it's like towing anything else (EOH brakes and a Ram 2500 6.7l Cummins). I rarely feel the boat back there when towing out here in California and we have to go up and over steep grades to get to the ocean. The only issue I've had was going across the Golden Gate Bridge, it has fairly narrow lanes but then again I have a massive boat behind me....I just took the space I needed.hehehehe Good luck with that. IMO the 265 is not a trailer boat. I pay the guy to come wih a giant hydraulic trailer
