PROP FOR BF150
adventure
I own a 1993 , 208 with a bf150 dealer maintained, present prop is stainless solas 14 3/4 x16 .
I use boat for fishing , mostly bay, here are the present conditions.
fuel on board approx. 30 gals, engine just tuned up, only myself as rider.
Boat will plane quickly normally have to get to 4000-4500 before it gets on plane and I start trimming motor up.
I need to run motor WOT to get speed up to 28mph, I have only taken it up to 6000 rpm but there seems to be more available .
Boat has clean bottom paint ,sits a little low because of motor weight , motor is mounted first hole.
I HAVE PRESENTLY NARROWED IT DOWN TO POWER TECH OFS3 15 1/4 X 15 OR OFS4 15X15, concerned about rattle at below 1000 rpm.
Is there anyone else with same setup that can recommend replacement prop.
