The yamaha black stainless props have a very good reputation, although they are not considered high-performance. But then, I'm not sure that a "high peformance" prop would make much difference with your application.
Here's a link to the yamaha prop options for the HPDI200:
http://www.yamaha-motor.com/outboard/ac ... all/1.aspx
I'll bet Andy at SIM would recommend the RELIANCE for your setup. If you went witht the 14-1/4X17 you would pick up a couple of hundred RPM at WOT for the smaller diameter, and because it's a little more efficient prop you might see a couple of MPH at cruise for a given rpm and a couple at WOT.
The Reliance is not as aggressive at the Saltwater Series. The latter has a more pronounced cup and in fact, are not even recommended for the F150. The HPDI200 would probably push them though, but if you went with the 15-1/2X17 you would probably lose a hundred or so rpms. I'm not sure that would accomplish what you want.
I tried a Reliance on mine and it was just a shade better than my 15-1/4X15 for the F150, but they are expensive ($600 ea) so it wasn't worth it to me. They are beautiful props though.
Write or call Andy and talk to him about what you have and what you're after and see what he suggests. He gets a ton of feed back because of his forum thread on THT.
If you could get a dealer over there to loan you a pair of Reliance props they would be worth a try. Most dealers will do that. But shipping from the states just to try them could get expensive. Plus, you have to justify any gains for the cost of new props. A pair of good stainless props is going to run from $900 to $1200 (USD) plus shipping.
I'm pretty sure Prop Doc will loan you props too, or maybe there's a prop dealer over there that will bring some props out and let you try them. Another option is to borrow a pair from another boat owner, that's pretty painless, but you have to find a generous boating buddy that would be willing to do that for you.
BTW, you mentioned measuring them without pulling them - make sure you pull them at least a couple of times a year and grease the splines, shaft and thrust washers so they don't get corroded and stuck. That's a real PITA.
Let us know what you end up going with. I'm real interested as I'll probaby end up with the exact same setup.
