Pump Out Head
Newman 70
Fisherman 216
Do you need a key (or tool) to open the pump out opening on the transom? The dealer said a key should have come with the boat but I don't see one.
look at Amazon Deck Plate/Fill Key There's all kinds at all prices. They are a standard key. West Marine will have them on the shelf.
Same key works on fuel and water fills
Or you can use needle nose pliers...
I use the pliers. They give you more leverage if the caps are tight. I use a pair of aluminum not too expensive fishing pliers. They don't rust. ( for the most part:))
It sounds like this is a new boat? Why doesn't your dealer give you one?
Depends somewhat on what style you have, though. Some use an external cap where you can grip the outer edge using your just your hand... although it would still have the two holes in it.
For the flush caps... Like mentioned, pliers work - and keys are VERY easy to find (to buy) just about anywhere.
