Question for Grady Owners for older boats 1997 are so
Roadworker
Long Island NY
I am thinking about buying a 1997 208 adventure boat fully loading bad is etec motor.
My question is been told by some surveyors to stay clear of these years boats cause of water damage. Has anyone bought a older Grady are have older Grady that can give me some insight on this.
Can you correct your first sentence? It's hard to understand.
But, with the jist of your post about whether it's a good buy or not... ANY boat that old can have issues. It really all comes down to how it was cared for. One thing, in particular, about the GW's is to look at the transom - notably the bang cap area - inspect that real well for the typical signs of water intrusion as GW didn't do the best of jobs there. Bounce HARD on the tilted up engine... does the transom flex?
The first sentence is boat is real nice except has a evinrude Etec motor hard they are hard to get parts for.
But my main question is been told by 2 boat surveyors on the phone ( they did not even look at boat ) to stay away from Gradys those years look for one in the 2001 and up range. They has to be people buying older boats
Ha! First sentence is still not a sentence! :)
But that's OK, I can decipher. I've "heard" that, too - but to be honest, I've never spent any time trying to find parts as I never had a need. Are they TRULY hard to find parts for? I dunno. Probably harder than other makes, though.
Main question is already answered.
I think they're possibly quoting two different things/years... in I believe 1997 Grady White switched from standard marine grade plywood to a product called Greenwood XL. It's supposedly a far superior product compared to your standard marine grade plywood at resisting water/rot, though it obviously can still happen. Grady White used it I believe on all of their boats up until maybe 2015 or so? when they switched over to a fully composite hull. So, I'm guessing the boat you're looking at will have the Greenwood XL, which is what you want to have. The 2001 and up range number usually pertains to those who are looking for a four stroke motor, as it was I believe 2002 when they gave the option for power on whether you wanted a 2 or a 4 stroke outboard. In 2005, at least for the 208 Adventure, they also increased the weight of the hull. It's speculated that this was to "beef up" and/or add extra buoyancy to the stern of the boats for the additional weight of the 4 stroke motors that were fairly new at the time. I wouldn't discredit or exclude considering looking at the boat just because a surveyor or someone says so. If you're potentially interested, check out the boat yourself in person, if you think it's worth your while then have a surveyor inspect it for you. If you know a fair amount about cars, boats and are remotely mechanical, you can usually tell pretty quickly the condition of something after looking around for a few minutes. You can buy things like moisture meters/readers for boat hulls online and measure it yourself, or you could bring along a rubber/plastic mallet and tap the hull to see if there are any soft spots.
In regards to the Evinrude E-Tec's, I couldn't really tell you anything you probably haven't already heard before. I believe it was Bombardier that was manufacturing them up until around 2020 or so, and then they came out with a notice saying that they were stopping production. My buddy has a 25' Wooldridge aluminum boat with I believe they're twin 175 E-Tec's and he's had a few problems with the lower units over the years, but on top of that he's had a few issues with finding people that will work on them. Mercury is supposedly doing the maintenance on the E-Tec's, but my buddy was saying that his local Mercury dealer wouldn't touch them. As you mentioned, sure I imagine that parts and availability of other things are likely getting increasingly more difficult over the years, as it's been roughly 6 years now since they stopped producing the engines/parts. Whether you want to go into that project or not is up to you, the actual condition of the boat/motor, how much the seller wants for the boat, if you're able to source some parts and whatnot for it, etc. The 208 Adventure also has a bang cap/plate on it, which if it's broken or missing entirely can let water into the transom. I'd definitely check it, along with everything else if you do go through with a pre-purchase inspection as you don't want to spend say $10k+ on the boat/motor to then have a bad transom that needs to be replaced and spend another $10k+ doing so. Here's a couple of links to websites where you can look up accredited marine surveyors, if you're going to pay to have someone inspect the boat for you. Good luck.
In addition to the potential transom issues, the gas tank may or may not be plastic. The plastic ones tend to last a long time since they don't corrode like metal tanks do. If the tank is metal it needs or will need to be replaced. Look at the deck and see if there is a caulked in deck panel that outlines the fuel tank. If there is no panel the tank is probably poly. You can also pop the pie plate just between the helm seats and tap the tank to see if it is plastic
Soft spots and delamination is very common on the locker covers especially on the lower lips. Same for anchor locker lid. Soft panels that are the 'walls' under the helm and starboard starboard side of the helm are common areas for rot.
If the vessel has a pulpit, that is also subject to delamination and cracking
The 'bad' ETEC motor has little value. A newer motor probably will need new gauges and rigging.
Depending on what engine and age engine you choose, it may cost more than boat is worth
Are you looking at the 1997 Grady White 208 Adventure on Boat Trader located in Brooklyn? If so, it says that the motor runs great? If not, might want to check it out.
Also looking at a 2001 226 but has a 2022 250 Yamaha on it still warranty like 180 hours fully loaded No trailer though and priced at $39,900 at Grady white dealer on Long island.
The 1997 is priced at $23,000 with Trailer
If the trailer were brand new, it might cost $3,000 - $4000.
That means the 208 with a ded ETEC is asking $20k. Way too much in my opinion.
If you decide to proceed, make sure the trailer has appropriate papers
