Removing Boat Name
Butcherboy
san diego
Does anyone have a tip on removing a painted name from the side of a boat put on by the previous owner? Thanks Tom
Jas
Annapolis, MD
I’ve taken a couple of vinyl names off the previous boats I’ve bought. Not too difficult. You can probably do a search and find some more details, but a hairdryer, needle nose pliers (or even tweezers) and acetone will get the job done.
Just warm up the vinyl and find an edge that you can begin to peel off. (A plastic scrapper will also help out here.) Hopefully if the vinyl isn’t too brittle you can get a runner going and get it off in big pieces, otherwise it takes a little longer. Clean up the old glue with acetone and then depending on any discolorization you can hit the spot with some compound of your choice. (I presume it’s white, but always be sure to match the hull color.)
Put new wax on and that ought to about do it. It may take some time to fade out completely, so expect that it won’t be perfect, but I think better than having someone else’s name on my boat!
Good luck, Ted
no problem
Pasadena Maryland
in the past on truck doors i've used oven cleaner and a plastic scraper if its paint and not vinyl. although i have never used it on fiberglass. then a wet sand with super fine sandpaper, and compound and buff.
Especially if you are superstitious!
Here is a discussion about renaming;
Superstition got you down? John Vigor offers tips for renaming your boat and keeping it lucky
By John Vigor
I once knew a man in Florida who told me he'd owned 24 different yachts and renamed every single one of them.
"Did it bring you bad luck?" I asked.
"Not that I'm aware of," he said. "You don't believe in those old superstitions, do you?"
Well, yes. Matter of fact, I do. And I'm not alone. Actually, it's not so much being superstitious as being v-e-r-y careful. It's an essential part of good seamanship.
Some years ago, when I wanted to change the name of my newly purchased 31-foot sloop from Our Way to Freelance, I searched for a formal "denaming ceremony" to wipe the slate clean in preparation for the renaming. I read all the books, but I couldn't find one. What I did learn, though, was that such a ceremony should consist of five parts: an invocation, an expression of gratitude, a supplication, a re-dedication and a libation. So I wrote my own short ceremony: Vigor's inter-denominational denaming ceremony. It worked perfectly.
Freelance carried me and my family many thousands of deep-sea miles both north and south of the equator, and we enjoyed good luck all the way. I used the same ceremony after that to change the name of my Santana 22 from Zephyr to Tagati, a Zulu word that means "magic" or "bewitched."
I'll give you the exact wording of Vigor's denaming ceremony, but first you must remove all physical traces of the boat's old name. Take the old log book ashore, along with any other papers that bear the old name. Check for offending books and charts with the name inscribed. Be ruthless. Sand away the old name from the lifebuoys, transom, topsides, dinghy, and oars. Yes, sand it away. Painting over is not good enough. You're dealing with gods here, you understand, not mere dumb mortals. If the old name is carved or etched, try to remove it or, at the very minimum, fill it with putty and then paint it over. And don't place the new name anywhere on the boat before the denaming ceremony is carried out. That's just tempting fate.
How you conduct the ceremony depends entirely on you. If you're the theatrical type, and enjoy appearing in public in your yachtclub blazer and skipper's cap, you can read it with flair on the foredeck before a gathering of distinguished guests. But if you find this whole business faintly silly and embarrassing, and only go along with it because you're scared to death of what might happen if you don't, you can skulk down below and mumble it on your own. That's perfectly OK. The main thing is that you carry it out. The words must be spoken.
I compromised by sitting in Tagati's cockpit with the written-out ceremony folded into a newspaper, so that any passerby would think I was just reading the news to my wife, sitting opposite. Enough people think I'm nuts already. Even my wife has doubts. The last part of the ceremony, the libation, must be performed at the bow, just as it is in a naming ceremony. There are two things to watch out for here. Don't use cheap-cheap champagne, and don't try to keep any for yourself. Buy a second bottle if you want some. Use a brew that's reasonably expensive, based on your ability to pay, and pour the whole lot on the boat. One of the things the gods of the sea despise most is meanness, so don't try to do this bit on the cheap.
What sort of time period should elapse between this denaming ceremony and a new naming ceremony? There's no fixed time. You can do the renaming right after the denaming, if you want, but I personally would prefer to wait at least 24 hours to give any lingering demons a chance to clear out.
Afterward
Now you can pop the cork, shake the bottle and spray the whole of the contents on the bow. When that's done, you can quietly go below and enjoy the other bottle yourself. Incidentally, I had word from a friend that the Florida yachtsman I mentioned earlier had lost his latest boat, a 22-foot trailer-sailer. Sailed her into an overhead power line. Fried her. She burned to the waterline. Bad luck? Not exactly.
He and his crew escaped unhurt. He was just very careless. He renamed her, as usual, without bothering to perform Vigor's famous interdenominational denaming ceremony. And this time, at long last, he got what he deserved.
"In the name of all who have sailed aboard this ship in the past, and in the name of all who may sail aboard her in the future, we invoke the ancient gods of the wind and the sea to favor us with their blessing today.
"Mighty Neptune, king of all that moves in or on the waves; and mighty Aeolus (pronounced EE-oh-lus), guardian of the winds and all that blows before them:
"We offer you our thanks for the protection you have afforded this vessel in the past. We voice our gratitude that she has always found shelter from tempest and storm and enjoyed safe passage to port.
"Now, wherefore, we submit this supplication, that the name whereby this vessel has hitherto been known _____, be struck and removed from your records.
"Further, we ask that when she is again presented for blessing with another name, she shall be recognized and shall be accorded once again the selfsame privileges she previously enjoyed.
"In return for which, we rededicate this vessel to your domain in full knowledge that she shall be subject as always to the immutable laws of the gods of the wind and the sea.
"In consequence whereof, and in good faith, we seal this pact with a libation offered according to the hallowed ritual of the sea."
Christening ceremony
After a boat is denamed, you simply need to rename it using the traditional christening ceremony, preferably with Queen Elizabeth breaking a bottle of champagne on the bow, and saying the words:
"I name this ship ___________, and may she bring fair winds and g
ood fortune to all who sail on her."
This article was taken from Good Old Boat Magazine, Volume 2, Number 4, July/August 1999
njdan
south jersey
I used the oven cleaner on 10 year old boat. IT worked very well. Spray on, let sit,stiff brush and power washer.repeat as needed. Not sure if power washer is even needed. Plastic scraper for tuff areas. As said above,you might end up with a ghost image. You can lightly sand or leave alone. My new name covered most of it and now I dont even notice it.
gwwannabe
Piankatank River, Gloucester, VA
My boat's old name can still be seen on the hull sides. Where the letters were, the gel coat is much smoother and a few/several shades different in color. I'm guessing the name was on there for many years. I compounded it last spring but it still shows. I doubt it will ever completely disappear but I'll hit it again this year.
Gary 89 Overnighter
JUMPNJACK
Chattahoochee Florida
Vigorously!
Hey seasick! Thanks for putting that info out there. I think Mr. Vigor has it covered. I am saving this info just in case I have a renaming opportunity. 8)
Re: Vigorously!
I enjoyed this story whenI first read it and saved it for the day that it was needed.
When I bought my boat (used) I was superstitoius about removing the name so i decided to keep it! I didn't know about the ceremony back then.
Butcherboy
san diego
rename
WOW!..a reason to have a party. Thanks for the replys, and I'll try to remember to ask questions on a regular basis......thanks again....Tom
SoutheastFL
Yep oven cleaner worked for me too. Use some light rubbing coupound or polishing compound to blend in the light area under the name with the surrounding color.
CJBROWN
Orange County, CA
Gary 89 Overnighter
Wet sand with 1000 grit and then compound. Grady gel coat is very thick but don't get carried away. :wink:
You need to get a uniform, flat surface, before polishing.
gwwannabe
CJ, thanks for the tip. You're right - the letters are raised enough that you can feel it as you slide your hand over them. If I can get up the courage, I'll give it a try.
Now that you've sold your boat, what are you looking for?
Gary 89 Overnighter
CJBROWN
Orange County, CA
Gary 89 Overnighter
Gary, all, here's an update: http://www.greatgrady.com/forum/viewtopic.php?t=13059
