Removing bow back rest cushions on 185 tournament
Isle boy
Tournament 185
I have a 2004 185 tournament, removing the cushions to have them reupholstered. the bow back rest cushions are not coming off and hoping someone can tell me how to remove them before I damage them. Tried forcing them upwards like the rear backrest cushions but not moving. Thanks in advance!
I just removed mine on a 2007 Tournament. Remove the phillip head screws that are put in at each drain grommet as shown below then slide up off the z clips. Here is a pic of mine with the cushions off. Take your time and use a good screw driver and apply constant pressure while removing, A couple of mine had stripped heads so I had to use a hacksaw blade and saw them off between the backside of the cushion and boat.
Good diagram. In some installs only a few of the grommet holes are used for screws. To find where screws are It may help to slide a very thin scraper or putty knife behind the bottom edge of the bolster and move it along until it hits something. That something may be a screw.
Reactions: JAdams1
wow, this is great! Guys that own the same boat. I love my 2005 185 Tournament. I will need to do this too at some point.
Look for some screws near the brass circular drain grommets. Take these out first. Then lift off per the pics above.
Thanks for the information! Found the screws and after removing them came right off. Appreciate the help from all of you!
Reactions: JAdams1
