I am removing a gas tank on a 204 overnighter. Directly behind the tank is a rib that runs between the longitudinal stringers. Is this in fact a stuctural rib or is it only for locking in the gas tank?
Also in removing the tank it appears I will need to cut the lip around the parameter of the deck hatch. I am thinking of using some type of rotary cutter, any recomendations?
Finally, since it would be difficult to replace the cut the lip around the parameter of the deck hatch, without grinding on the finished deck. I was planning on using 5200 to adhere a new deck lip. The weight of the deck hatch is supported by rib/cross members, with the lip providing a sealing point for the silicone.
Let me know.
Let me know.
