Removing Waterline Stains
JayT
Wake Forest NC/Salter Path NC
After many years of salt water boating I am still looking for a non acid hull cleaner that works. I have used On-Off, toilet bowl cleaner, Barkeepers Friend and a couple of others. Has anyone used a non acid based product that works and does not require a lot of scrubbing? Overtons makes a non acid hull cleaner that has one review that says it does not work. Any other suggestions to help reduce gel coat degradation while getting the hull sparkling clean.
I use a product called FSR - fiberglass stain remover- that I learned about here on GG. It does a great job on the skum line and even removes rust stains but that takes several treatments.
Gary 93 Gulfstream
