Repairing small screw holes with epoxy
Wrestling Coach
Buffalo, New York
I will be removing two transducers from the back of my Tournament 19. The screw holes remaining will be small and I think marine epoxy will fill them. Is there an epoxy product that can be tinted to match the cream colored hull? Could I use woodworking stain to alter the color? Other holes will also be in the dash. Thanks in advance.
Dennis
Hi,
You can buy the GW gelcoat if desired from the dealer or direct from the supplier. I can't recall the manufacturer, google and I'm sure you will find it. They had a color chart with the Grady color. Easy to apply and can be lightly sanded.
NOTHING ELSE MATTERS
LONG ISLAND NEW YORK
You have to use thickened epoxy, not just plain epoxy. You can make a some by adding silica in the epoxy mix and also you can tint the color you like by adding pigment in it.
