Replace rear sink faucet?
osubux1
Freedom 307
This might only apply to Freedom's, but perhaps some other models have a similar setup. This faucet (and sink) sit in the aft right behind the helm seat on my Freedom. Below it is an enclosed area with a sliding door pull out garbage can directly under it. As you can see, the faucet is really corroded and I'd like to replace it. It wasn't until I unscrewed the garbage compartment that I could see how to access the underside of the sink/faucet. So, I can now see how to get to it at least. But, has anyone ever replaced these? It's a tight fit underneath and I'm guessing a bear to reach and unscrew / screw back on. And, in dealing with water/connections, etc. I really want it done right. Not that I don't trust myself, but my local marine mechanic shop does good work.
Yeah, working on boats is often a testament to your yoga skills! What you're dealing with is very basic plumbing so that part is easy. As you said, it's access - without being there and seeing things in person I can't fully comment, but it sounds like you found your access point. BUT... I see a cupholder - removing that might help. Is that sink binded to the countertop or screwed to mounting blocks or maybe uses 2-part attaching hardware where you can remove the sink? How 'bout the right of the sink - is that another cabinet? Is there a removable partition? Or maybe there's a good spot in the partition where you can drill a large access hole and cover it back up with a pie plate (or if it's not really seen, just leave the hole).
Again, I'm obviously not there and you have a much better seat to see what's going on - but hopefully the ideas above will help and give you some ideas.
Reactions: osubux1
I replaced two in the cabin this past summer - the ones I removed were easy (2004) to remove. They actually came out by turning the nut at the base of the handle. I looks like yours might be the same - New ones have changed and they were installed similar to a household faucet, from below - As Dennis said most jobs are space constrained on these boats :). Attached is a diagram of the install for a hot/cold water faucet. I assume yours will be similar. The OEM was Scandvik and they ran about 250 bucks each. Nothing cheap about boating! Good Luck
Yours do not look too bad - they would clean up a little with Flitz and a Drummel polisher. The spayer and faucet handles could be replaced if you did not want to do the base. All parts available from Scandvik.
Reactions: osubux1
Yeah, all of the things you point out do not provide any type of entry under the sink area. To the right is a marble lid to a fully encased storage area and the fridge is underneath of it. So, I'm back to yoga. :cool:
You nailed the price exactly. $250 from Defender. From what I can tell, it loosens and can be removed from below.
All of the things? Doesn't the cup holder help - that looks like some really nice extra access for a second hand.
Fridges aren't too hard to remove.
Sink removal?
Sink removal?
I'm not near the boat right now, but when I looked, it didn't lead me anywhere. The fridge is further to the right. The removable garbage compartment sits in the best location.
Oh, I thought you were there at the boat. It'll make more sense when you're there. You've got a bunch of ideas to think about. Things like this typically aren't all that bad once you get eyes on it.
One other thing if you ge new - there is a very small black washer that goes on the hose where it connects to the faucet body. I lost it in the bilge while practicing on being a contortionist inside the refrigerator cabinet space. - The washer was not available anywhere I searched except Scandvik.
There are several nice tools for tight location plumbing fixtures. Do some googling.
You can just have the marina do it and pay them what they want. its going to be $$$ for labor. You can get an exact replacement or something nicer. Thats going to be $$$.
After thats done, it will turn green and look crappy in only a couple of years.
You can do it yourself and save $$$. If there is a garbage can in the way, I guarantee it comes out with a couple screws.
You can go cheap and buy a $10 chromed plastic RV faucet and it will look new for just as long as the $250 chromed brass one.
Its outside the cabin so maybe you want the hose... you can just replace it with a plastic sink hose kit from Home Depot or Amazon.
https://www.greatgrady.com/threads/265-not-so-fresh-water-tank.37764/post-279261
