My 1986 offshore 24 is going to need a new bracket for twin outboards in the very near future. Over the weekend i started removing the sealant around the bracket to drive to reseal it. When i got to the bottom of the bracket i found alot of corrosion under the sealant and in the lip area and under the bottom paint. Is there a company that makes a direct bolt on replacement? I would like to be able to reuse all the exsisting mounting holes in the transom and not have to play with motor heights. Or option b remove the bracket, sandblast it. apply jb weld to corrosion area's sand smooth and repaint
