I am ready to replace the plastic teak toe rails and covering board trim with HDPE from Finadict Marine. I was just wondering if the corners are mitered as on a picture frame or butted as is the current trim around the cut out for the gunnel mounted fishing rod holders. If you have the almond HDPE toe rails, please check the joints on the trim around the rod rack cut out and reply as to which way they are cut. The angles are kind of goofey so I feel that mitering might be a bit of a pain.
