- May 31, 2020
- Age
- 60
- Ventura County
- Sailfish
I know that there is another thread regarding props. I just didn't want to interfere with original thread.
I have a 2001 282 Sailfish that has twin Yamaha 200 2 stroke with a 4 blade props (OFS4R14PCL200) 15 1/4" diameter x 14 pitch. I replaced the original 3 blade props awhile back because the props were original with the boat and needed an upgrade. You can tell they were tuned a number of times and had a couple of dings when I first got the boat.
With the new 4 blade props I definitely got some serious torque and it planes in seconds. Top RPM's was about 4800. I did lose about 10 MPH top speed and about 1/2 a mile per gallon of fuel efficiency. Which adds up when your talking range.
Now I'm going to repower with Yamaha 4.2L 250 4 strokes and planning on using the same props. I would think that with more power the RPM's will max out around 5500 and 50 mph max.
What do you think? Research tells me it's going to be a good combination. Engines are going on Feb 1, so within a couple of weeks after will be test time. I'll keep you guys posted.
