repowering single engine to dule
John Morreale
Palm Coast
I have a 1987 24 Offshore with a 225 Johnson. I'm thinking about repowering with dual 115 or 125 hp my mounting plate is for single engine only. How can I find a dual mounting plate. I could use any help you are willing to give. Thanks John M
Mounting plate or bracket mount? If its a bracket mount, there are several manufacturers that make them like Armstrong and others...some are aluminum, some are fiberglass.....also, look to see if anyone or any boat yard has used ones in good shape from previous repower jobs...maybe Iboats.com has something.
If its a flat plate you're talking about that bolts against the transom, you may just need to buy a peice of flat stock and make your own....
