Rule 500gph livewell aerator pump
steviedatsun
new york
My livewell pump went out, it is attached the water inlet on the bottom of the boat. The pump I believe is original, and says on top LIVEWELL/RULE 500GPH/AERATOR. Does anyone out there know the proper name or part number for this pump. I would like to replace it ASAP.Thanks Steve
Replaced mine several months ago. I replaced the Rule 500GPH pump with a Rule 750 GPH pump for more water flow/volume. You can find Rule pumps at West Marine, ur dealer, etc. in three or four sizes. Fairly easy replacement in my 272 Sailfish. Rule is the manufacturers name, and the pumps are sized by GPH (gallons per hour). The larger pumps(1000 or >) have a larger diameter thru hull adapter. 500 or 750 will work well......
