- Jan 31, 2005
Thought I'd start a winter discussion thread and ask folks to share some stories and hopefully lessons learned from things done to them by others. Can be good or bad.
I believe I had two small thefts on the boat during winter layup (maybe more that I'm not aware of)...
One year I was late to spring launch and in a rush to get the boat to the slip. I had a fishing excursion planned and wanted to be able to follow through on the commit. I layup about 45 minutes by boat from dealer to slip so I take her back and forth each spring and fall. Boat is launched, on the dock and ready to go. I take the launch to the floating dock perform an operational check and I'm off like a prom dress. I get about 3 min away outside the harbor and decide to stop and prep the boat to slip. I clean out the boat very well in the fall and put everything back in the boat in the spring ensuring I touch and inspect everything as it goes back in. The only things I leave on the boat are (4) fenders and (4) 30' dock lines. Everything else comes out. I put other things in the v-birth storage lockers in the spring, so I move the fenders to the aft fish box and one in the live well until I prep to dock. I place the dock lines on top of the fenders in the aft fishbox as there are installed on the cleats, so they are ready when I arrive. I went to grab the nice new black dock lines and they are gone. At this point I'm a tad concerned but remember that I keep a couple of spare lines under the mid berth. When I rotate new lines in, I keep a couple of the older ones for storm ties or if I unexpectantly need to dock. Lucky I had these lines, or I would have been in deep yogurt at the dock as I was alone. I told my dealer/owner about this and I could tell he thought it strange (who would steal lines) and probably didn't believe me. I wasn't looking for repayment or anything more just sharing the story so he knew things can happen on the hard in the yard.
Th second one was just detected this year. I say this because I'm not sure when it actually happened. This past fall I removed my anchor and rode as I figured it was time to replace the rode after 15 years of use (yea probably a little late). At the end of the season, I drop the anchor and rode from the boat on the hard and bring home. A few weeks ago, I decide to get cracking and order the rode to prep for spring. I pull it out and find that I only had 15 feet of chain not the 30 I thought with 300 feet of line (BTW this seems to be a standard config sold by Lewmar and others). I noticed a square piece of metal welded to the bottom anchor V that I didn't remember being there. I also noted that my Delta Fast Set anchor now said Marpoc on it. I recall noticing rust on the bottom of the anchor last fall and was surprised by it. Now some may say maybe you thought it was a Delta from the beginning. Being a tad anal, I use some elbow grease and hit the anchor each spring with the metal cleaner so I'm familiar with the anchor. I then remembered I peeled off the two blue Delta stickers off the anchor a couple of years ago as they were faded, and a bit chewed up. When the boat is wrapped the anchor is used as a hold point and the shrink wrap is wrapped tightly all around it. No way the anchor could be removed post shrink during layup without being noticed. I ended up getting a new rode (recommend Dark Horse Marine in Fl on the web with free ship BTW if you need a custom one) and bought a "used" Fast Set off Amazon. I worked for Amazon developing robotic and industrial automation equipment for their fulfillment centers (know their operation) and found a "used" one in excellent condition for 2/3 the best price I could find. I've had good luck with their warehouse items from time to time. I'm guessing the label is beat up and they are selling at a discount. If not, it will go back, and I'll order a new one. I also keep a lighter weight Danforth anchor and rode in a Coors Lite 30 pack zip cooler to keep the noise down.
The lessons are:
Be observant and pay attention to your equipment. Inspect and replace anything that is out of date, worn or missing.
Keep critical item spares on the boat if possible. Be prepared - stuff happens.
Ensure you have your lines and fenders before leaving for home port.
Coors 30 pack zip coolers make decent noise mitigation containers for storage areas on your boat.
Don't peel the stickers off your anchor. It would have been much easier to see the anchor was swapped if I left them on.
The lessons are:
