Seafarer 226 Livewell Install
Skip759
I'm looking to add a live well the the port side cooler box of my '02 226. I have the Grady specs (at lease what they offer) and know there is a thru-hull in the box and another in the hull about 2" above the port side cooler drain line. Can anyone provide some pictures of the location of the cooler box thru-hull and the plumbing inside the access panel. It all looks pretty tight for 1.5" tubing and fillings.
The fill line would be 3/4” from the livewell pump up to the tank. The overflow would be 1 1/2”. Some are set up to overflow into a removable stand pipe that goes in the drain in the bottom of the tank. And some drain out the side at the top of 5he tank.
