Seafarer Wood Bulkhead Replacement
Norcoastal
The bulkhead between my cabin and helm on my 1988 Seafarer is completely rotted as I’m sure most 1988 Seafarers are. Has anyone replaced the bulkhead with mahogany with a gloss poly over it like the big boys?
Those of you who have replaced the rotted bulkheads, can you post some pictures of how you replaced them and describe what you did?
This is my first Grady project so I’m still learning.
Maybe Starboard would be better?
Thanks!
Starboard isn't structural, I'd skip on that. I'd go with either marine plywood or exterior grade plywood. The latter is likely cheaper in todays market and will last the duration of the boat. I'd cut to size, screw to what you can either tie into existing structural elements or cleat in to hold and then glass the entire piece (all sides overlapping existing glass).
Hey Fishtales, why wouldn't you first build the panel and glass it ,then install it ? plywood likes to absorb water through the edges with capillary action of the grain of the wood. I think at a minimum you would want to at least coat or encapsulate the panel in resin , getting the edges really well, then glass it in? What do you think?
Thanks for the reply’s. I’m sure this is a very common issue with many old Grady’s.
I‘d like to find out what others have done with pictures. Also, my idea of solid mahogany, that may be an option and it could look great...
Mahogany will last longer than you or I and boat put together. Stain it and put a nice urethane spar coat and you're in business.
Reactions: PointedRose
Marine grade plywood, epoxy the edges and bottom where water can deteriorate it.
Then you can either paint or laminate a veneer of you choice on it to finish. I painted my with oil based enamel to match my trim.
Use the old bulkhead as a template to cut the new.
Reactions: Holokai
Wow, that looks great. You just used a jigsaw to make those cuts? Really well done. I was considering starboard but I’m concerned about rigidity.
If you don’t trust your self with a jigsaw, and you still have good edges on the original pieces, you can clamp or screw them together and use a flush trimming router bit to finish cut your new panels. I would rough cut it a quarter inch outside the line with a jigsaw, and then router the finished edge.
That’s what I did for my anchor locker replacement lid, when I installed a windlass.
On my 2000, I am getting a brown stain weeping out from underneath the portside bulkhead, but I can’t find where it is coming from. Mine has about a 4“ x 1/4“ baseboard glued and screwed to the bottom.
Sounds like wet wood - that will give off brown-stained water.
This wasn't always done (if ever?) from the factory, but any wood that is used should have (as noted above) the edges fully saturated, multiple times, with resin. At minimum, the wood should NEVER be put down such that it touches the deck. There should be an air-gap so that the wood, even if it gets wet, will continually dry out. Installing wood tight to a surface is just asking for trouble.
If yours is tight to the floor, you "might" be able to save it by trimming the bottom edge to leave about a 1/4" air gap.
I agree Dennis. But I don’t know whether it is coming from washing the deck, or dripping down from above. If it is from washing down, I could caulk the joint, and hope that it will dry out. If it’s coming from above, The caulk would just create a dam.
Yep jigsaw, just took my time with the cuts ;)
Without seeing it, it's tough to say, but if I had to guess... the water is wicking up from the floor. If it was dripping from above, you should be able to find obvious soft spots. Do you have an oscillating tool? You could cut the bottom 1/4" off while still on the boat. Me, I'd rather leave a 1/4" gap than caulk. Caulking won't allow it to dry and it's also possible that a small area of the caulk fails and again allows water in. The gap shouldn't be an issue with water getting into the cabin since the cockpit floor should have a built-in lip.
Yes, can do that if desired. May be better. I think either way you do it, the repair will stand the test of time for the hull.
I am replacing mine right now since boat is down for total boat drain and bilge and water line replacement, I am using 1/2 inch birch plywood and use laminating resin with styrene thinned and coating the plywood until it will not suck up any more then without the styrene going to apply 2 mat and 2 cloth layers of glass to all edges and front and back of panels so they will total encapsulated then going to finish with 2 part paint to match boat, I cut the panels 3/16 short on all edges to make up for the glass buildup, will set bulkhead back in with caulking between floor and bulkheads.
Some of the wood veneers today are pretty impressive when coated. With that you could use any composite depending on your comfort level. The debate is long on which epoxy is the most UV stable but you could opt for a urethane.
I’m debating now what’s the best to do. I’m now leaning towards 1/2“ marine ply with 1/4“ starboard, but that could change tomorrow. I’m thinking that because the cabin has some wood the inside would be natural
So the thought is to put the starboard on the outside? I wouldn't bother. Actually, you run the chance of water getting between the wood and SB. Honestly, it would be a waste of money. Marine ply is better than exterior grade PT ply. Saturate the edges and outside with epoxy. The outside is now fully waterproof, but also will take paint nicely. Still leave a small gap under the bottom edge. Do whatever finish you want on the inside... use the epoxy again... stain it... poly... whatever you want.
I’d really like some sort of plastic on the outside so it’s easy to clean and stay nice for a long time.
This isn’t as easy as I thought.
All I know is that I made a real mess
