semi-permanent flushing system
everwhom
Cape Cod and Nantucket
I always flush my engines after each trip and I rigged a Y-hose with quick connects to make it easier, but I decided to try rigging a semi-permanent setup so the hoses stay attached all the time and I have a single quick-connect (so sorta like the rigged flushing systems that newer gradys come with).
I bought all the components from McMaster. The hardest thing was finding the right tubing at a reasonable price - you need about 10 ft. The hose listed below is the one I should have gotten -- instead I have the thinner version which works fine, but isn't ideal.
1 2 Packs of 1 each 6222T23 Barbed Garden Hose Fasten-on Fitting Nylon Adapter for 1/2" Hose ID x 3/4 GHT Male Delivers Tuesday 1.89 3.78
2 1 Pack of 1 each 6222T24 Barbed Garden Hose Fasten-on Fitting Nylon Adapter for 1/2" Hose ID x 3/4 GHT Female Delivers Tuesday $2.31 $2.31
3 1 Each 5047K95 Tight-Seal Moisture-Resistant Barbed Tube Fitting Plastic, for Air and Water, Tee Connector, 1/2" Tube ID Delivers Tuesday $2.50 $2.50
4 1 Each 7082T24 Plastic On/Off Valve with Garden Hose Threads Delivers Tuesday $3.07 $3.07
5 1 Each 5034K15 Abrasion-Resistant Firm Neoprene Rubber Tubing for Air and Water, Opaque Black, 1/2" ID, 3/4" OD, 10 ft. length Delivers Tuesday $18.30 $18.30
6 1 Pack of 10 each 5011T171 Worm-Drive Clamp for Firm Hose and Tube 316 Stainless Steel, 5/16" Band Width, 1/2"- 29/32" Clamp ID Delivers Tuesday $12.50 $12.50
Reactions: HMBJack
