shoot thru hull transducer for 222 ?
knot@work
I bought a 222 fisherman and am thinking about installing a Lowrance's shoot thru hull transducer at transom next to where
the bilge pump is located. Has any body done this before ? Is this recommended by GW factory ? If so, how to installe it properly? Thank you for any advice !
Whatever you do, test fit it first. Know for certain you have no bubble issues, and the bilge pump doesn't create electrical interferance before you stick it down. I always use silicone seal to mount a transducer to the hull. Works well, and can be more easily removed than epoxy when time to replace it. And for heaven's sake, don't even think about 5200! :wink:
