- Feb 2, 2021
- Age
- 45
- Chase
I recently repowered my Chase 263 with a Verado and replaced the old Yamaha gauges with two Go7 XSR with VesselView. I have the Simrads on a NMEA2000 backbone with the TotalScan transducer run directly to one of them (the only configuration bc it obviously can't go directly to the backbone). I am not getting a depth reading on ANYTHING except for Downscan and it only works on the unit that has the transducer plugged into it. Echo, Fwd, Side, etc don't work (period) on either unit nor does the depth reading on any screen. You can even see in the pic the depth is indicated for Downscan, but not on the right toolbar / pane (which is where I need the reading as that carries over into Chart, Verado gauges, etc). I know if you long press that portion you can select the "source" and it lists the two Go7 units. It's set to the one with the transducer, but I tried the other for kicks wo any success. Any ideas??
