stbd vent window came out of it's hinge
tim2527
I have a 2002 Sailfish. Does anyone know if the vent window can be pressed back into the frame? It seems tight and I'm not sure if I can tap it in with a rubber mallet.
Any suggestions?
West Palm Beach, Fl.
ttles714
NJ
Remove the screws that go through the glass...... angle the window all the way out and it will go "back into the groove". Reinstall the screws and all should be good. Do not force it into place, at the exaggerated opening angle it will fit right back into its channel.
tim2527
thank you, it went back in with no problem.
