Huh? If you pull one of the hoses out of the rear of the pump, how does that work?Use the ATF on the tabs and fill from the rear. Much easier than taking that pump out or messing with syringes and droppers. Stick the hose in the quart and run raise the tab on that side.
No - hose from the stern before the bulkhead fitting. The pump will draw the fluid out of the quart.Huh? If you pull one of the hoses out of the rear of the pump, how does that work?
Oh, OK, gotcha. I've never had a boat where doing that would be less time consuming than filling directly into the reservoir. But, hey, to each his own!No - hose from the stern before the bulkhead fitting. The pump will draw the fluid out of the quart.
Ya, Grady decided to put the res under a compartment. It has to be removed to fill. Tabman before his passing gave me that tidbit. He said it is usually far easier with only needing fluid and a wrench.Oh, OK, gotcha. I've never had a boat where doing that would be less time consuming than filling directly into the reservoir. But, hey, to each his own!![]()
