Stereo Questions for 2019 Freedom 285
kas919
Venice, FL
Hello. The boat we purchased a few months ago had a non functioning Fusion AV 755. I had a gentleman replace the stereo with an RA670. The cockpit speakers work great. The right bow speaker is not working. I did try to test it at the radio with a spare speaker...no go. Perhaps a glitch in the wiring harness? Lastly, the rear gunwale speakers are not producing sound. Does anyone know what zone is Zone 3 because I believe that may be the one linked to the auxiliary amp. It's hard to dig around in that port helm area. Any thoughts or suggestions would be greatly appreciated. Thnx. Kurt
If all of the speaker wires don't go the head unit, which is likely, then they go to your amp. Find your amp and check wires... then ID which wires go to which speakers. You can switch them around to test speakers, too.
Same boat, different year. I may be able to help, a little. On my boat, there was an amp hidden under the steering wheel. There was also a subwoofer speaker aft of the port seat. My system, using a Fusion head unit was a disaster. I eventually eliminated the amp completely and took the outputs from the Fusion head unit directly to each speaker. Since I only had a four output head unit, I eliminated the subwoofer. Now, it works fine, is much more simple and there was never a need for an amp or subwoofer to begin with.
