- Aug 14, 2024
- Age
- 49
- Virginia Beach VA
- Express 330
Hey folks,
I have a 2004 330 Express. 2013 300 Yamaha 4strokes. They purr like kittens at all RPMS. Everything is great except for one pesky, hard to duplicate issue. This issue only happens when I'm climbing out of the hole and the bow is up so I suspect that is has something to do with the deck angle. It does not happen at WOT or any time after I'm on full plane. It doesn't happen at idle or any RPM low enough where the bow is down.
From idle in gear, as I advance the throttles to come up on plane, sometimes at about 3500-4000 the engine(s) will suddenly shut down. Sometimes its the left motor, sometimes its the right motor. Sometimes its both. They fire right up afterwards and can run the rest of the day just fine. I have tried about 15 hole shots trying to get it to do the same thing and it won't repeat itself consistently. It just happens maybe 1 out of every 20 times. I checked the fuel filters, I'm running new fuel, it does it on both tanks, and I have more than half tank of fuel when it did it the first time.
Ideas appreciated.
FinAllie.
Ideas appreciated.
FinAllie.
