sump pump
freddy063
Maine
I have a 1994 sailfish 272 and at the helm the first breaker is marked sump pump. What is this for, both bilge work and this breaker is broken. So what would the sump pump be? :huh
If you have air conditioning it is likely the condensate sump pump.
Hi,
I also believe the head floor drains into the sump as well. If you took a shower, the sump would catch hair and any other debris so it didn't go into the bilge.
ok shower pump> that would make sence. The float was sticking , and that might be why it will not reset. Thanks, Fishtales and wspitler for the information, i see said the blind man. :goodjob And I also forgot to winterize it last year, I bet the pump is gone. Thanks , you guys are great.
