Teak and Holly Flooring
pablor
Hi all,
Does anyone know how hard it is to remove the teak and holly interior flooring from a Grady 360? Trying to see if it is glued down so hard that it would have to be taken out in chunks. Mine is very scratched and I figured it is cheaper to remove than refinish.
Thanks in advance
Hi,
It is glued down over the fiberglass sole and should come out as one piece if you take your time. It is a solid piece of material that I believe is 3/8 to 1/2" thick. You should be able to find a sheet and use the existing as a template. I had mine removed when it discolored due to an install issue. Water got into it. After laying down, ensure you caulk all around the edging well. This is where my problem started as water got between the layers and turned spots black with mold.
Good luck.
Reactions: Angler Management
