Through-keel windlass on 257 advance
Elins9iron
Advance
Has anyone installed a through-keel windlass on a 257 advance? Is there enough room?
Thanks,
Can you explain what is a thru-keel windlass and maybe post a link to it?
Windlasses are installed on the bow area, either together with anchor in a holder/roller on deck or windlass is belowbow deck under a hatch and anchor exit thru a hole on bow.
If you don't have the windlass cover hatch then you should install the windlass on deck and use a bow roller who can lock the anchor in place.then you need to drill the small holes for the windlass and a bigger hole for the chain dropping down in anchor locker.
Your 257 Advance has a anchor holder but it's made for manual recovery and storage and from th photos i found i don't see enough space for a on-deck windlass and installing one below deck would be a hefty fibreglass job to make a box with a sturdy basement and cutting a big hole for a access hatch.
Much more simple and definitively much less expensive is the use of the old school Anchor Ball for retrieving a anchor, but you need space for the retrieve maneuver, nothing for the sand bar or crowded places.
Chris
Aside from the massive job and cutting a hole in the structural part of your bow keel...
Open up your anchor locker... look at about where the windlass would mount... is there room for it? How much "fall" will there be for the windlass you choose and what are the specs for that measurement of the windlass you choose? Assuming you're good at doing the structural work... the answers to those two questions will let you know if it's even possible.
Reactions: Sardinia306Canyon
Ive seen the windlass installed on the top of the bow on the 257 fisherman (looks very similar to the advance), but not through keel. Just curious if it would work or if anyone has done this. I like the clean look and the stainless plate. I haven't seen it done on either of these models, so I doubt it can be. It would be nice to see if anyone has, though.
Thanks,
Thanks,
Sure - but you can answer your own question by doing what I mentioned above.
If you're thinking about tackling a windlass install, then I'm sure you can handle reading a spec sheet and using a ruler :)
Although... I would hope someone could handle reading and doing simple measuring even without the skill set to do a windlass install ;):):p
