Thru-hull fitting size - seafarer 226
TIDE
Chesapeake Bay, Maryland
Need to replace the thru-hull fittings at the water line on my 94’ seafarer 226. Any idea what size they care?
You really have to measure. They could be 3/4", 1", 1 1/4" or 1 1/2". Get inside and get the hose off. I use a step drill bit to get them out from the outside. Destructive but they will not be used again.
Important note: The hose ID is not the thru hull od. Measure them!
