You are over powered. That being said, Here is what I experienced. I was told by Burt @ GW It would be fine to replace my 200 2 strokes with 200 4 strokes. "In fact the added weight should help the boats ride".The hull likes to ride on the back of the sponsens like skiing on 2 water skis. You side to side problem and list is coming from too much speed, not enough lift AND improper Trim. I use the motors first then trim tab down a little for max speed at an rpm. 30-32 MPH. Four blade props gave me the lift in the stern to help the side to side problem 95%, It was the best money I spent on the boat. The Power Tech props have been awesome. Find out the weight difference in your motors and mine and see if it is too much if not get the 4 blades and do not run the boat over 35 mph staying off the SuperChargers is what I would do. I have a 1998 F26 with 08 Yamaha 200s. In 2000 I was told by GW it was the best riding hull they have ever made, GW Having one as a Company Boat. It was never designed to be a Go Fast Boat, It's all about the ride. Good luck and let me know how it works out for you.
