Tilt trim unit removal
I am down to the last bolt on the bottom. I have removed the two security clips on either end. Is it one bolt that just needs to be loosened and pushed out to one side or the other?
Thank you! Mine is really in there. Push from port or starboard? Which side do I need to apply force
Yes I did! Thank you I got it out. Just took a little force. I am sure it has never been out.
When you take the rams apart, note what direction the ram seals face if they have a v shaped groove on one side. Some years do and some don't.
Reactions: Germanmattlanta
