My AP pump is under the outside sink, behind the tackle drawers. Power cable reached my under gunnel Stbd side On/Off switch. 9ft I think...maybe 11?
Your windlass is not ideal on that 10awg from the terminal block. When you run it, it will cause a big voltage drop. I suppose people get away with it because when you are pulling your anchor you are not running AP. Lewmar V700 for instance recommends 6 awg (for a 60ft round trip)and the use of a solenoid to control it.
I ran the radar down the hardtop pipe to the terminal block. No need to add wire.
fyi, you need to run the radar network cable first, before power and N2k and whatever. You need room for the connector to fish thru.
One end has a removable thread. You will need a hole in your hardtop at least that big. I recommend putting the removable end up top and the fixed end on your 1243.
You only have one Garmin network into the hardtop for radar. I had three garmin network cables for Radar, sonar black box and another MDF.
The Garmin Marine Network cable is NOT pinned the same as a standard ethernet crossover.
Try not to cut that cable! You need a tool, connectors, a diagram, and really good eyesight...and luck....
