Transducer Location on 366 Canyon
SeaSaw
:hmm
Any suggestions on where in the hull to install a B260 Airmar/Simrad transducer on my 366 Canyon with 3 x 300? I will be installing the Simrad NSE 12 system and the boat will be held on a lift so the bunks are a concern.
On my 336 the transducer is dead center on the keel right under the helm. You should call Grady for the correct answer, they will get you also some drawings/schematics of your boat.
Thanks I did speak with GW when I did the tour and that's the approximate location they gave me as well. My concern was that the Airmar instructions indicate mounting the ducer "to the side" of the motors. But I suppose motor interference isn't a concern that far up the hull.
