Transducers
HTHM
Mount Hope, On, Canada
Is it possible to have a through-hull transducer on a Gray White?
Back when I owned a Ranger Bass boat I was able to mount my transducer in epoxy resin at the bottom of the bilge and was able to get very good readings.
I assume you are referring to a "shoot" through hull ducer? A "through hull" would entail drilling a larger hole. If that's the case, then yes. You don't mention the model, but I believe all Grady's have a solid FRP hull bottom. "Maybe" the bigger ones are cored - not sure.
@DennisG01 thank you for correcting my terminology. A shoot through is was I meant. The model Grady White I am hoping to get is a 190 Tournament or Freedom.
