- May 8, 2014
So I pulled the old scuppers off the transom (265) and saw that two of the three drain tubes were not flared on the outside of the transom... The flare on the inside on the middle drain had corroded and broken off, so I was keen to replace at least that one... I chiseled out the middle and starboard tubes, and didn't note any issues with the wood inside the holes - all seems solid, no sponginess, no cracks... I did notice that the transom measures about 3.25" thick at these holes, and and even 3 " at the port hole (with the intact tube)...
The boat stays on a lift, so it is dry (and has been since 2013 when I bought it) most of the time... Should I have any concerns regarding my transom? I am planning on replacing the tubes this week, and am planning on replacing the scuppers with the stainless stick-on ones from the stern pad folks...
Thoughts?
Thoughts?
