CD, I think we're on the same page here. When a builder is done with installing the wood core and has finished the outside and inside skin, the boat moves over to hardware installation and finishing. They drill holes for the drain tubes, deck drain thruhulls, cleats and wire ways, which exposes the wood core (especially end grain) all over again. To make it water tight, the proper way would be to resin/glass the hole and then gel coat the hole (for finished look purposes). That would make the hole as water tight as the rest of the boat.
But that takes extra time to do and extra time is money to a builder...so they're not going to hold up production for that....so they simply "seal" the thruhull with caulk, they only use a rubber or plastic boot for the wire ways, and they mechanically "sleeve" the drain holes with a brass (which should actually be bronze for marine use) or in your case, PVC tube because its faster and more cost effective for them. But as you can see from the numerous posts about wet cores, each one of these areas have shown to allow water into the wood and causing rot. If they took the time to do it right in the first place, these caulks, sleeves and boots would be out of the equation...the only protection the core needs is resin and a little glass...the rest of these items would be more for appearance, as they have shown not to be worth anything as far as long-term protection of the core is concerned.
So IMHO, they are not necessary if the job was done correctly in the first place. The PVC in your case will work for a while and longer than the brass, I agree, but using resin/glass and a little gel coat for looks is something an owner can do now if he or she is thinking about replacement, and should last indefinitely.
