Trim Tab Wiring
Tucker
Port Deposit, Maryland
Ok, just got my new Bennets mounted and working on the wiring. Is it best to wire to an unused accessory switch, ignition switch, or to main hot wire coming into the console? Thanks guys...
You talking about hot wire for controller? You have options there as described in the instructions. Do you want auto retract etc?
I preferred the ignition switch, this way display is not on unless key is on.
