has anyone used the thru hull underwater lights ? and apart from looking preety have they made a difference to your night time fishing results?
gradyfish22 said:Don't have them on my boat, but most guys in my are who fish tuna have put them on, or use a hydroglow light in the water. It will not help you catch fish...fishermen catch fish!!!(joke) Underwater lights do attract more bait to the boat if your fishing an area full of life which then attracts the fish. I think it is well worth adding, but here is the question...on your boat how are you powering them? Not sure if I would run it off your main battery bank and risk killing the batteries far offshore. Some underwater lights draw less then others, so if you do add them, be aware of how much current they use and make sure your system can handle it. Know that on your boat you cannot run your spreader lights all night wither, that will also kill your batteries. Not sure if I had mentioned to you, but I am adding a new lighting system for offshore fishing on my 165 this spring. I'm adding 2 Pyramid Technology HID lights, 3x the light and 1/3 the current. Off a good sized battery they will last all night. I am putting a new battery in the Stbd Bench seat and using it only to power the lights so I cannot kill my start batteries. I will keep the battery off the boat and charged at home until I run offshore, hook up the terminals and I'm in business. I may also add underwater lights from the same company, they draw a slight bit less then others and are not true through hulls, they stick out 1/2" from the hull and only require a 1/4" hole drilled through the transom. They are LED lights. Each light is $200 a piece(total of $400 for the underwater lights and $400 for the HID lights.
Your other option to having lighting all night is to buy a small Honda generator and to strap it on the bow when running offshore. My friend has it on his 265, it cost him slightly over $800 installed. His dealer did a very good job, if interested in this, try Hobby Lobby Marine in Toms River, NJ. They did a very neat install and I'm sure they could send you all the parts and instructions as to how they did it, they are very good people down there. Reason I do not like this is that you will have a shore power chord running from the bow to the transom. Not a fan of a wire in my way when fishing and the possibility of someone putting a gaff or hook into it. Also, I'm not sure if I like having more stuff on my bow, I already strap a 6 man canister life raft to the bow, and if that generator takes a wave over the bow, I'm curios to see how it will last over time. I'd also rather make less trips to the bow if possible when overnighting. Those are your 2 options, and why I choose my method, not saying it is right for you, but I did a bit of research and these are the 2 solutions I came up with. Let us know what you decide to do.
