- Nov 30, 2016
If your boat doesn’t have a Hard Top or T-Top, then it’s nearing the time to install one of these USA-Made Carver Bimini tops to protect yourself from the brutal sun and heat that is quickly approaching!
The easiest way to choose a Bimini top for your Grady White, is to select your year and model from our search guide, then choose the material and color that best matches your needs.
https://www.boatcoversdirect.com/products/bimini_tops/GRADY_WHITE_198/
If you have already decided on a size that will fit your boat best, you can choose your own dimensions as well: https://www.boatcoversdirect.com/products/bimini_tops/by_dimensions/
There are many upgrades to choose from, including Stainless steel fittings, Full stainless frames, brace kits, slide track kits, etc. so you can customize your Bimini top however you’d like!
https://www.boatcoversdirect.com/products/accessories/#bimini-tops
Carver Bimini tops are offered in an array of materials and colors, including Sunbrella. With warranties extending up to 10 years, Carver delivers a promise of superior quality and durability. Key features of buying an American made product are superior components including nickel-plated brass eye straps and adjuster buckles, and double-walled main bows for the ultimate strength in your top.
If this is all new to you and you're not quite sure what you need, give us a call so we can help you work out all the details! Be sure to mention GGRADY10 to receive your additional 10% discount off the online price!
Happy Boating!
Shannon with Boat Covers Direct
866-626-8377
shannon@coversdirect.com
Happy Boating!
866-626-8377
