Voyager Vs. Gulfstream real draft numbers
Morehead
Good morning. There are varying numbers for draft on the older (say 2001) 24' Voyager and 23' Gulfstream. Does anyone have good info on that, and are the published numbers for an "empty" boat or are the numbers accurate for for a boat with fuel and basic gear? Thank you.
:uhm Use 18" and you'll be as close as you can measure. Pretty sure it's an empty hull and no motor, but Grady can probably confirm ...
I have a 2000 GS with twin 200's. I ran a ground a few weeks ago @ about a Ft of water :bang ...Finally after a little manuvering I got freed up @ about 1.5-2ft so i would say 18" is the lowest you can go without getting stuck
