- Sep 1, 2010
Bilge has always been dry until I had my freash water pump replaced and the washdown repaired (kinked hose) may not be related but seems so. The water is leaking somewhere forward of the bulkhead right behind the fuel tank from the bleed hole at the bottom of the bilge. I can soak up all the water from the stern area and watch is slowly seep back in. All thru hull cocks are off including the maserator. Took it back to shop but said they couldn't find a leak. Thinking of putting food color dye in freash water tank to see if that's it. Any thoughts?
