What am I looking at? Gulfstream 232
jmenende
Howdy folks. Just upgraded to a 1999 gulsftream 232 with dual ox66 150hp. I think these are fuel pumps but im not sure. The lines come from the valves, through them and out to the engine.
Also, I have included another foto of a valve that connects to the toilet outlet. What does it do?
Thanks in advance.
I think those are lift pumps but I am not sure why you would have them with OX66 motors that have their own low pressure pumps.
The second pic is the overboard discharge/pump out selector valve. Normally it should be in the pump out position and either disabled with a lock, a tie wrap, or by removing the handle. It would only be unlocked when discharging waster tank contents in legal water areas.
Technically even if the selector is in the dockside discharge position but not locked/secured, you can be fined.
Reactions: jmenende
The OX's lift pumps have a finite lifespan because of being made out of a thin rubber diagphram. Generally, an electric lift pump is more reliable.
That said, I've neve personally seen an electric fuel pump that looks like that - not to say that I've seen everything, though. But I'm curious aobu the "T" being used.
Reactions: jmenende
The valve controls waste outlet. Center hose is the pickup from the shi_tank. one hose goes to a deck fitting for dockside pumpout. the other goes to a macerator pump. from there it uses a smaller hose to an underwater thruhull that also has a valve. You also have another valve for water inlet to the head (toilet).
The other things are definitely fuel pumps but I've never seen them before. I had OX66s. Did not have those. They are unusual. Maybe they recirculate?
Interesting. Can you see a name or part#?
Reactions: jmenende
Will take a closer look and report back.
That loop between the inlet and outlet is strange. My guess is that the fittings are check valves and the loop passes gasoline when the primer bulb or motor fuel pumps 'suck' gas.
I also thought that the devices were related to some sort of fuel flow monitoring sensor but that seemed less likely. That said, if you follow the fuel lines you can see in the upper right area some sort of device with a wire going into it that the fule line connects to. That may be a fuel floe sensor.
