- May 10, 2020
- Age
- 58
- Far Rockaway, NY
- Seafarer
Hi everyone, I have a 1986 Seafarer 228 (F225 on a bracket ) with a live well along the transom, and a hose. The live well and wash down hose are supplied via a seacock selector. I have a Sureflo Blaster. it doesn't really "blast" as it is a 3.5 GPH pump. The live well seems VERY low flow compared to the hose, additionally the intermittent droning every other second I really don't like AT ALL. It does not aerate as much as just add new water flow. It is handy that it has a pressure switch I suppose and I generally can leave it on with the hose attached. I often use the live well and keep the bait for several hours, so leave the live well pump on when live-lining or fishing with Killies.
at any rate I would like to jettison the Sureflow. what would you guys replace this with? is there something I could replace straight into this system as-is ? would you go for 2 separate pumps? keep the seacock? I've read about Groco, Jabsco, Johnson. I'm not even sure what the difference between a pump and an aerator pump is so any advice will be welcome.
