Which Model Bowthruster 2007 Marlin
Meanwhile
Warren, OR
I'm trying to order shear pins for my bowthruster but do not know the model number of the factory installed BT on my 2007 Marlin. The boat is 90 minutes away. Can another Marlin owner give that information?
Whoops, should have looked for the 2007 parts pdf.
BOW THRUSTER 300
07–100 Bow Thruster Housing
14–458 Cable Kit For Bow Thruster
16–626 Fuse Block ANL (For Bow Thruster)
16–627 Fuse Amp ANL (For Bow Thruster)
22–467 Panel Bow Thruster
23–511 Tunnel GRP 185mm x 750mm x 4mm
23–513 Battery Disconnect Device (Bow Thruster)
23–515 Joystick Control For Bow Thruster
23–525 Bow Thruster SP55S w/ 7m Control Harness
24–336 Sealer Poly Adhesive White Bostic
24–398 Screw Phil Pan MS SS 5mm x 12m
