Windlass question: Gulfstream 232 - simpson-lawrence sprint 600
Keitha
Orange County, CA
Original windless simpson lawrence sprint 600. Can this windlass drop anchor w/o using power. I'm hoping I can freefall the anchor when needed.
thanks,
If it has the 8 point socket on the cap, you should be able to loosen the capstan and it will free spin. You need a special wrench. Sometimes a square drive breaker bar (1/2 inch I think) will fit the 8 point socket.
This is it. It does have the 8-point socket. Do I just put the wrench in that and loosen it from the top?
Yes, you need to loosen the cap. It may be difficult and you may need to hold the capstan. Be very careful. When the cap is loose the anchor will at some point deploy very quickly. Keep your fingers clear
i'll try it. I have the safety cable on the anchor, so no premature-deployment possible, but appreciate the heads up.
