Winterizing 330 express in water
readafore
Brigantine, NJ
I am keeping my 330 express in the water through the winter. Wondering what needs to be done to salt water washdown system to winterize. I am emptying fresh water tanks and flushing with RV antifreeze and pumping out head and running a gallon of antifreeze through the toilet. I have someone winterizing the ac/heating system and generator. Anything esle I'm missing?
For the saltwater washdown, close the seacock, disconnect the hose from it, open all your saltwater outlets and blow air with a compressor or a shopvac into the hose you disconnected from seacock. Make sure you buy a water circulator and throw it in the water on the side of your boat, so salt water doesn't freeze around your boat. Tip: If they(dealer)recomend you a specific size for the circulator, get the next size bigger.
Not sure where you're located, but I hope your boat is OK after the hurricane.
