I posted this a while back. My Port tach quit functioning. Digital readout is faint to not visible. RPM is not correct Two error arrows show, one heat one oil.
It was sugeted that I check my ground for the tach. My slip neighbor said to put one lead of my multi tester on the tach ground and the other lead to a known good ground. If voltage registers then there is a ground problem on the faulty tach. He also said that a bad ground will backfeed current to a diode in the tach causing the diode to gradually fail.
I tested my grounds and no voltage registered. Any suggestions?
One thing I noticed was that when the ground to the fuel gauge was disconnected and one lead was touched to the disconnected ground from the gauge the meter registered 5+ volts. When the gauge ground was reconnected to the main ground the voltage read 0.0V. I cleaned my two tank sender connections at the tank end first.
not being an electrical wizard, I'm confused by all this.
