‘96 272 Sailfish macerator pump location
Palmolotte
Where is the holding tank overboard (macerator) pump located on a ‘96 272 Sailfish? Thanks
Palmolotte
Thank you. Do you know if there is anything to try to get the pump going again, short of pulling it from the tank? The fuse is good and there is power to the control panel and tank wire connections.
Andrew93
Massachusetts
There is a writeup somewhere where someone abandoned the in tank macerator in place and added an external one with a y valve through the pump out port. I think there was one specific to a 272 Sailfish I saw somewhere but this link is the same idea
Palmolotte
Appreciate your help. I looked at the pick and looks pretty straightforward. I’ll see what kind of space I have.
ScottyCee
Samish Island, WA
Rebuilding mine was easy. It had seized, and was very dirty - looked like a throwaway but it actually cleaned right up. There’s a thread with some pictures of that process. I would assume it would be a lot easier to get it spinning again then it would be to re-design. Ymmv...
Palmolotte
I hear u, not sure I want to handle/clean crap. Do u know if reversing power wire connections will reverse rotation. Wondering if going back n forth With rotation might free it up.
ScottyCee
Samish Island, WA
Ya. Mine wasn’t that kind of dirty. The motor had seized. I don’t know about polarity and direction but I doubt that work work to free it up. Wear gloves. Lol
Most macerator pumps have a small rubber boot on the end of the motor, which covers the end of the shaft. There is a screw driver slot in the shaft fof the purpose of freeing a stuck shaft.
Palmolotte
Thanks. Looks like I would still need to remove it from the tank to get to that rubber boot, which I’d like to avoid if possible. So far, it’s pointing to investing in a hazmat suit!
Even if the macerator is in the tank, it is hard to believe that it is being used as a submersible pump, rather than having its own space. I just replaced my external macerator, and the motor end did not strike me as submersible, but I wasn't looking for that.
Someone who has been there give us the dirty truth.
ScottyCee
Samish Island, WA
Definitely submerged. I'm telling you was ready to throw it away, but this one works perfectly now. The shaft had seized, but otherwise it was fine. it may have been replaced at some point, as the bearings don't seem 20 years old...
Palmolotte
Decided to pull the pump out today and it was relatively easy, other than getting the discharge hose off the elbow fitting. It’s a ‘96 so after 24 years being clamped and not mush room to get a good grip, had to cut the hose off the fitting. The pump looked cruddy and the shaft was seized. I let it sit inverted with a few drops of mouse milk oil for 10 minutes then took a drill w/ 11mm socket to the shaft bolt at the macerator blade. Got it to turn right away and then reinstalled it. Appreciate everyone’s responses.
