I would think a 60” shaft would do the job and 80 pounds of thrust. I have the same boat and would like to see how one is mountedanyone on here have a bow mount trolling motor on a 192. it will be used in fresh water. I would like to see a picture of it mounted if possible and I'm mainly want to know what lenth shaft that you used?
thanks
Which lower unit trolling motor did you install?I ended up with a lower unit mounted trolling motor. The rails and all I just decided no bow mount.
Im very glad I did.
24 volt and plenty to move my tournament at 3-4 mph.
steering wheel steers you.
Out of the water when on plane.
simple dial control on the dash.
awsome boat ramp upgrade.
I know, not programmable, graphing hummingbird tho.
But, another plus, wife and I can cocktail and putt along the shore, no noise.
my 2 cents.
Minn Kota
24 volt
80? Lbs
Dash mounted dial control.
two batteries under starboard rear seat.
